Old 24-Aug-2017, 10:01 PM   #4
golfknut
ViewTV VT-0966V Digital Amplified Outdoor / Indoor Attic HDTV Antenna sold by Amazon.
Specifications:
Antenna Frequency Range: VHF: 174-230MHz / UHF: 470-862MHz
Amplifier Frequency Range: VHF: 47-230MHz / UHF: 470-862MHz
Number of Elements: 4
Antenna Gain: 10-14 dB
Amplifier Gain: VHF: 24 dB / UHF: 30 dB
Mile Range: 165 Miles
Front-Back Ratio: 15-20 dB
Impedance: 75 Ohm
Amplifier Gain Adjustable Range: VHF 9-24 dB / UHF: 15-30 dB
Amplifier Max Output Level: 102 dB u V
Amplifier Noise Figure: < 3.5 dB
And the antenna is pointing at 240 degrees and only a few trees may be in sight path, but sparse at best.
I'll try the FM filter/trap as Rabbit73 has suggested. I guess I don't understand all I need to about antenna.
Thanks, for the replies.
golfknut is offline   Reply With Quote
