Old 24-Aug-2017, 5:06 PM   #3
JoeAZ
Hi Paul,
The antenna you have is excellent for your situation.
Quite possibly, the TV Fool analysis may have overstated
the signals to your area. I would start over, using much
of the same equipment. Connect your antenna to ONE
TV via a 50 foot or less RG6 cable. What do you receive?
Open a window, second floor is possible, position your
antenna out the window with someone holding it. Connect
it to One television. What do you receive??? If both of
those do not provide a satisfactory signal for your stations,
then a roof mount might be a necessity. You are going to
need to experiment which takes time, patience and effort.
