Old 22-Aug-2017, 10:00 PM   #1
golfknut
Cool Missing major OTA signal
Hello all, I recently cut loose from Directv and put up an antenna, but I can't seem to pull in the OTA signal from what should be the strongest of all channels in my area. I can get FOX, NBC and CBS but no ABC.
[URL="http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de6a49e565724aa"].
Antenna is rated for up to 165 miles. Antenna Frequency Range: VHF: 174-230MHz / UHF: 470-862MHz | Amplifier Frequency Range: VHF: 47-230MHz / UHF: 470-862MHz.With a Channel Master CM3414 4-Port Distribution Amplifier
Any ideas what I can check?
golfknut is offline   Reply With Quote
