Old 14-Aug-2017, 6:56 PM   #6
The 300ohm balun for the antenna might be bad, but I think it is a combination of the hill and the trees that scatter the signals from 144 degrees. The scattering is frequency-dependent which explains the different reception for the channels from that direction.
scroll down to Trees and UHF
If I didn't know about the trees and the hill, your report would make me suspect tuner overload from your very strong signals, and I would suggest trying an attenuator in the coax.
Can you show us a photo of the trees in the WNYW Fox direction?
Would you be willing to give me the coordinates of your antenna in a PM so that I can look at the satellite view?
