KYCW-LD is using the antenna previously used by now-gone KSPR at just a bit over 1800' AGL.
I have to tell you I generally despise the 7777 because it's used so inappropriately so often. Too many people think that more gain is better and it usually isn't. If that thing was kept behind the pharmacy counter and sold only by expert prescription, I'd have a very different perception about it.
Powering multiple preamps with a single line can be done, it does require some knowledge about the amps in use, some creativity and it's not without its possible drawbacks.
