Thread: 91XG or DB8e
Old 9-Aug-2017, 7:34 PM   #5
jrgagne99
You can likely improve your system noise figure for your UHF antennas by around 4 dB by amplifying them separately before combining the signals in your reversed splitter.
He would need splitter that passes power through both ports, right? Does such an animal exist? Can the CM-7777 power inserter supply enough current to power two pre-amps? He would also need a UVSJ that passes power through the UHF side (or passes power through both ports and put a DC-blocker on the VHF port), right?
