Old 9-Aug-2017, 1:05 AM   #10
Billiam
I've got the very same problem at my home. Trees and taller building surround it. I resolved the very same issues that you mention by using a stronger antenna and a rotor. Now I rarely have any dropouts on my weakest signals. Also use a pre amp which has helped greatly despite the fact I am in a strong signal area. Signals are so weak at my location that the pre amp apparently is not overloading at all. Just make sure if you use a pre amp that you buy one that is less prone to overloading in strong signal areas.
