Old 8-Aug-2017, 2:28 PM   #7
mogulman
ok...I looked again.. The antenna is actually pointing between two trees. I think I can clear some branches between, so there are no leaves at the level of the antenna, without it looking too funky. I'll have to wait until the roof dries.
I don't think I want to move the spot too much from where the antenna is mounted.
Any use in trying a larger antenna also, after I cut the branches? not sure what the next step up would be, or if anything else would fit in this area. More than likely I would probably need 2 steps up to really notice anything.
Attached a pic of where it is currently located.
There is one item that is making the situation worse, too. One of the stations in the Denver area, Channel 20, 20.1. I think they are having problems with their transmitter for the last month. There is nothing on their web page, but I messaged them on facebook. They said it is operating in low power mode until they can get the transmitter fixed.
mogulman is offline   Reply With Quote
