Old 4-Aug-2017, 12:04 AM   #13
JoeAZ
Originally Posted by lefty832 View Post
I bought the winegard 7694p, so what type of mast and mounting should I use. I would prefer eave mount but we live in a manufactured house and the roof pitch is not the steepest,
Hi Lefty,
As mentioned earlier, I would use either a used Dish/Directv mount or you
can buy new. MCM Electronics sells a 39 inch "J" mount for 10.99, part
number is 33-10915. You should be able to mount on your fascia and not
have to penetrate your roof. Before you drill any holes, have someone
hold the antenna in the proper direction, about where you think you may
mount and do a channel scan. If everything comes in well, great. If not,
the person will need to move the antenna up/down and around a few
feet to see if the reception improves. Hope this helps...... Joe
