A closer look at the location shows that the Binghsmton stations would require a tall mast of around 30'. Reception of Utica and Syracuse can be done with a shorter mast. A DB 4e aimed north would be the simplest installation. A second UHF antenna for Syracuse would eliminate the rotator, but require two preamps and an external tuner (or an A/B switch).
