Old 30-Jul-2017, 10:56 PM   #5
JoeAZ
Welcome Lefty!
You are fortunate to have very good signals for all the major networks
as well as independents and PBS. You have several antenna options at
the very least. My favorites would be the Winegard 7694P available
at Home Depot.com, Walmart.com and Amazon for around $40.00.
Another good option would be the GE 29884, also around $40.00
including the mount! Available at Amazon.com every few days at that
price. The Clearstream 2V, priced about $80.00 with the mount would
also be a good choice. Keep these things in mind. Use a good RG6 cable
using no more than 50 feet to one television at first. Avoid nearby trees
to your North. A roof mount should not be necessary. Before you drill
any holes, have someone hold the antenna about where you'd like to
mount it. Another person inside should do a scan for reception. It may
be necessary to move the antenna up, down, or otherwise to get all
your available channels. Be sure to properly ground your system. It
protects against lightening and can also enhance your reception as well.
Keep it simple, especially at first. Add more tv's later on........
