Old 27-Jul-2017, 8:26 PM   #8
Frugal1SBM
Wow, Rabbit73! Thank you for your clear and concise instructions. I have not peaked into the attic crawl space but it would solve the visibility issue and allow the antenna to be in the peak of the roof.
I will pick up the antenna with the reflector in case we need it. I took a couple new photos of the roof while running a load over today. As noted right now beyond those young trees there is open field and a golf course to the north. There will be houses being built across Whitehaven in the next several years which may impact me once they are in place. I can hope that the gaps in the houses will thread the needle for my directional settings.
Are there extenders for the dish pole that would allow me to get it a bit higher but still unobtrusive to the current roof line? Also since the signal strength is so strong on 3 main channels I understand amplification is counter productive. What about boosting split between TVs?
Frugal1SBM is offline   Reply With Quote
