Old 23-Jul-2017, 11:01 PM   #7
If the tvfool report is correct, it should be OK down to WJXX.
If the filter makes ION weaker, then you will be able to use a preamp.
Mileage figures don't mean much; they are just marketing tools. What good is a "50-mile" antenna if you have a hill five miles away that is in the signal path?
What counts is the strength of the signal at your antenna.
