Old 23-Jul-2017, 9:29 PM   #6
TX1228
Thank you both for your time and recommendations. I also appreciate the advice for a mounting method. I'll start with this and see what happens.
If I do have to put in a filter to reduce the ION channel strength would that antenna still be sufficient to reach the other channels down that bearing that are approximately 50 miles out?
TX1228 is offline   Reply With Quote
