Old 1-Feb-2011, 1:56 AM   #7
John Candle
Tv Antennas and Reception
Ok with the Winegard HD7698P antenna and a Winegard AP8275 preamp mounted at about 20 feet high , point the antenna between 247 magnetic compass and 210 magnetic compass. The weaker stations are at 210 magnetic compass so point the antenna more in that direction. Finding a position that the antenna receives more of the signals of the weaker stations at 210 and not to much reduction of the stronger signals at 247. If 1 Tv is connected do not use a splitter to connect it , If 2 Tv's are connected use a 2 way splitter , if 3 Tv's are connected use a 3 way splitter , If 4 Tv's are connected use a 4 way splitter. The signal is reduced each time a split takes place.
