Old 20-Jul-2017, 9:02 PM   #3
JoeAZ
I'd agree with Rabbit that you do have a difficult but not impossible
situation. I also think the Winegard 7698p gives you the best
chance to receive the channels you want. Hopefully you do not
have trees which block your view to the Southeast. I'd use a "J"
mount and initially try keeping your home between KTLM and
your antenna. Your home could block the worst of the KTLM signal.
A roof mount is probably not the way to go.
The added height would help reception in some ways but cause
overload from KTLM. This means mount somewhere on the South
side of your home. I would suggest using a RG6 cable and run
it to ONE television at first. Keep your cable run 50 feet or less.
Be sure to ground your system. This should get you started.
Please check your private message inbox.....
