Old 16-Jul-2017, 3:31 PM   #2
JoeAZ
Location is everything with reception. I would try moving your
antenna higher or lower on the mast. It might be necessary to
move your antenna a few feet either way. You should also
attempt to rotate the antenna a few degrees at a time and see
what happens...... Amplification might cause you more problems
because you have some very strong signals nearby. You may
also wish to configure your antenna with the panels in different
directions. Please do not start any new threads for the same
issues. I had to go back to your original thread to follow and it gets very confusing. Thanks!
