Old 15-Jul-2017, 1:26 PM   #2
JoeAZ
Greetings,
You are fortunate that you have so many strong signals from
different television markets. I would suggest the Antennas
Direct Clearstream 2Max. It will give you good bi-directional
reception either on your roof or in your attic. If you have lots
of trees nearby, try to position the antenna as far away as
possible. You'll need to experiment to see which location give
you the best reception of the most important stations to you.
If you choose to mount outdoors, be sure to properly ground
your system. It protects from lightning and can enhance your
reception as well. Use a good RG6 cable and keep it under
50 feet, if possible. Hope this gets you started. Keep it
simple, especially at first. Connect your antenna to ONE television
at first, add other televisions later, if you need to.
