Old 14-Jul-2017, 9:36 PM   #15
JoeAZ
In this case, you may NOT WANT to mount a roof antenna.
It will be better to use your home as a block to WICD.
A "J" mounted antenna, properly grounded, gives you, by
far, the best chance for success..... You can mount on
the eaves, on the side of your home or even from a ground
mast. Be certain to keep the antenna away from trees so
it has a good view of your weakest signals...
