Thread: Outdoor Antenna
Old 14-Jul-2017, 7:50 PM   #24
Whats's the difference between MCM 30-2475 and 30-2476? They both look same to me.
The 2476 is a little bigger and has a little more gain than the 2475. KFMB and KGTV are your strongest signals, but you are behind a hill. They both have a tilt feature that will allow you tilt the front end of the antenna up which sometimes helps when you are behind a hill. You get to decide which one.
Also is there a huge difference between Antennas Direct DB8E and Solid Signal HDB91X for UHF? or is that just because of future KDSN relocation?
The DB8E has more gain at the low end of UHF, but it is more expensive. Fox and PBS are on 19 and 30 right now. The HDB91X has a tilt feature; the DB8E does not.
