Old 14-Jul-2017, 6:11 PM   #13
JoeAZ
Originally Posted by corson6 View Post
Thanks for all the replies! JoeAZ - do you couple these two antennas you suggest? What directions am I pointing them? Once I'm in the house with the RG6 what's the best way to distribute the signal to multiple TVs?
I would start simple. Order either the 4 bay UHF antenna from MCM which
are currently on clearance for about $19.00 or the antennas direct c2v
or antennas direct 4 max. Connect the antenna of your choice to one
television on a temporary basis, through a door or window. One person
watches the tv, hopefully with a signal meter, and the other positions
the antenna on the roof. I'd start your aim at about 250 degrees which
will help reduce the overload from WICD. Continue to rotate clockwise,
260,270,280 degrees, scanning for your channels in each position.
You might just be able to receive PBS from WEIU and not need any VHF
antenna at all. It's not an easy prospect but if you can position the
antenna where it cannot be seen line of sight by WICD, you have a
decent chance of success.
