Old 12-Jul-2017, 11:59 PM   #4
JoeAZ
Great!
A couple more things to keep in mind. Keep it simple, especially
at first. If you have a set with a signal meter, I would suggest
you connect one antenna with 50 feet of RG6 Cable through a
door or window. One person watches the TV/meter and the other
is on the roof, moving the antenna about, looking for the best signal.
Repeat the same for the other antenna. Antennas should be
kept at least 5 feet apart. You can achieve this by using a 10 ft
or greater mast or using two mounts, one for each antenna.
Hope this helps.......
joe
