Old 8-Jul-2017, 6:49 PM   #3
A good tuner should be capable of rejecting adjacent channel interference that is up to 33 dB stronger than the weaker desired signal. WNJT is 33.1 dB stronger than WNYT; close call. What helps is that WNJT is in a different direction, so if your antenna is aimed at WNYT, that should make WNJT weaker.
ATSC Recommended Practice:
5.4.2 Adjacent Channel Rejection
The receiver should meet or exceed the thresholds given in Table 5.2 for rejection of first adjacent-channel interference at the desired signal levels shown above the columns therein.
WNJT will be moving to channel 23 on a sharing basis after "repack":
http://www.rabbitears.info/market.ph...&callsign=wnjt
WNYW on 44 will be moving to 27:
http://www.rabbitears.info/market.ph...&callsign=wnyw
WTXF on 42 will be moving to 31:
http://www.rabbitears.info/market.ph...&callsign=wtxf
