Old 6-Jul-2017, 7:05 PM   #22
Tower Guy
The closer CBS has a worse NM -1.2 which will make it harder to get than the further one. My bad on the NBC, it is close, but still a low NM and Kw at the antenna will make it hard to get.
Actually, 30.2 KW on channel 6 is high power for low VHF. Yet TVfool does not subtract the 4 db extra low band noise that is added into the FCC coverage of low band. Even then, none of the antennas suggested are designed for low band.
The difference in noise and the higher gain of UHF antennas will make reception of WFSB easier than WRGB.
