Old 5-Jul-2017, 6:26 PM   #13
Tower Guy
In your case I would consider the AD 91XG or one of its clones for your UHF antenna. This is because your hardest network is CBS with both WFSB and WCBS on channel 33. They will interfere with each other unless you have an antenna with significant front to back ratio. The 91XG beats the DB-8e by 10 db. I agree with the suggestion of the MCM VHF antenna and the TV-PRAMP-1. The antenna location should be as clear as possible toward Hartford.
You may not get everything with this setup, but the most critical networks will have the best chances.
