Old 5-Jul-2017, 6:19 PM   #3
JoeAZ
Amazon has a SPECIAL on the Winegard 7698P. You may also
want to try Walmart.com. Be sure to keep your RG6 cable run
as short as possible. Keep things simple, especially at first.
One antenna to one tv. Add things slowly, like more tv's, etc, etc
so if you start having issues, it is easier to identify the cause....
Keep the antenna as far away as possible from trees and be
sure to ground your system!
