Old 4-Jul-2017, 1:59 PM   #9
mjcarpino
After taking another look at the tvfool report, it looks like I might be able to receive CBS, NBC and FOX pointing the UHF antenna JoeAZ suggested. By directing both panels to 50 deg would hopefully have the most gain. If it works, I'll try adding a VHF antenna to get ABC pointing at 107 deg. I plan to get the MCM 30-2430 antenna first and if this fails I guess I have to forget OTA tv. If it works, the next step is to add a VHF antenna with a combiner/amplifier which bring up the next question. Is a separate combiner amplifier better than an all-in-one like the Channel Master 7777. I would like to purchase/install the MCM 30-2430 and combiner/amplifier in preparation to adding the VHF antenna. Any suggestions regarding what devices I should consider to combine/amplify these weak (or non existent) signals.
mjcarpino is offline   Reply With Quote
