Old 28-Jun-2017, 12:48 PM   #2
The C2MAX is a far better choice than the DB8e since you have both UHF and VHF as well as stations in nearly opposite directions.
Your actual results will be mostly determined by how well you pick a suitable mounting location. A spot that gives the clearest available line of sight in BOTH required directions is the best location, everything else goes down hill from there.
