Old 27-Jun-2017, 2:41 AM   #9
You certainly have given me a lot more intel than I could find with KOCE 50 PBS SoCal here locally.
You have to go here for more:
http://www.avsforum.com/forum/45-loc...a-ota-336.html
KDOC channel 56, but as I previously mentioned, their engineer that I spoke with in the past told me the signal strength I was receiving was as good as it was going to get.
KDOC is only allowed to send about 30% of its max ERP in your direction because of the border agreement.
http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d8
KDOC is on real channel 32, the channel that is used by the transmitter. If you must use the virtual channel number, please state it as 56.1 to avoid confusion. You are no longer a newbie; use the real channel number, callsign, or both.
KDOC will be moving to real channel 12. That is the channel that will be used by the transmitter. It is the real channel number that determines which antenna you will need for reception.
VHF-Low, real channels 2-6
VHF-High, real channels 7-13
UHF, real channels 14-51
The virtual channel number (like 5.1) is a holdover from the analog TV days to maintain the identity of the station, and is what the TV displays.
http://www.rabbitears.info/market.ph...&callsign=kdoc
I've got to figure out how to leave a quote in grayscale
It's easy; select the text and click on the quote icon.
