Old 24-Jun-2017, 1:14 PM   #107
tripelo
Compare: Antennas Direct DB8e & CM-4228HD
Antenna tests conducted on June 15, 2017.
Objective: Compare performance of selected VHF antennas while receiving DFW TV channels.
Antennas:
1. Terk HDTVi (as reference)
2. Antennas Direct DB8e
2. Channel Master 4228HD
Terk HDTVi antenna measured as reference (see previous posts).
Both Antennas Direct DB8e and Channel Master 4228HD are panel type antennas, also known as 8-bay antennas.
Main differences between the two panel antennas are feed system design and reflector backplane.
Images of antennas shown below:
Channel Master 4228HD (below)
Test Location:
Garland, TX, ~30 miles line-of-sight to DFW stations.
Test location TVfool info posted earlier:
Compare Preamplifiers - Test Procedure & Configuration
Test Equipment and Test Procedure:
For details of test equipment & procedure, see previous similar tests:
Compare Received Signal Strength of 5 UHF Antennas
Compare: Antennas Direct C5 & Televes Yagi B-III
Credit:
Thanks to forum members ADtech and re_nelson for providing the Antennas Direct DB8e antenna.
(To be continued)
