Thread: Outdoor Antenna
Old 23-Jun-2017, 6:05 PM   #8
Originally Posted by adyoon View Post
Hi
It's been a while and I have not installed an antenna yet.
I found a person to install so please give me any recommendation on antenna.
I am sure there is a better one out there compare to 3 years ago.
http://www.tvfool.com/?option=com_wr...e6a449bcb394f1
Well, since you asked, but nobody has directly answered:
An MCM 30-2476 aimed at 175 degrees magnetic for CBS and ABC.
http://www.mcmelectronics.com/produc...-2476-/30-2476
and an Antennas Direct DB8E with both panels aimed at 138 degrees magnetic for Fox, PBS, and NBC.
Combine the two antennas with a UVSJ UHF/VHF combiner:
https://www.antennasdirect.com/store...Combiners.html
The output should go to an Antennas Direct Juice preamplifier.
A less expensive but less reliable alternative would be an RCA TVPRAMP1R preamp with the input switch set to separate, which will combine the two antennas because it has separate UHF and VHF inputs.
How well this will work will depend upon where the antennas will be mounted and if there are any objects in the signal path that will block the signals.
