Old 22-Jun-2017, 5:44 PM   #9
JoeAZ
Just a couple of thoughts....
Be sure to ground your system.
Use good quality RG6 cable and keep runs
as direct as possible. Runs over 50 feet can
reduce the signal and/or require amplification.
Keep it simple. Start with one tv and see
how it goes..... You can add additional tv's
later, once you've established a pattern of
reception. Higher is usually better. This is
particularly true in your area. Those hills
shred the tv and radio signals, causing
reception problems...
Good Luck!
