Old 31-Jan-2011, 11:02 AM   #5
Ok I suggest a Winegard HD7082P antenna with a Winegard HDP269 preamp , mounted on the roof. . Replace the distribution amp. with a Simple 3 way Splitter. . Direct the antenna at about 216 magnetic compass. The channels to receive are the Digital Channels. If any of the analog channels are received then Ok , if not then Ok. . KCXW 5 The CW is very strong station and might be received with this one antenna. . If not , and you will like to receive it then I recommend a Simple Non-Amplified indoor antenna directed at channel 5 and a Remote Control A/B Antenna Switch from Radio Shack at the Tv locations that will like to receive channel 5 , so as to switch between the outside antenna and inside antenna. Here is how to aim Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html . . Here are simple indoor Tv antennas , http://forum.tvfool.com/showthread.php?t=233 . Read and understand this about Real Digital Tv Channels and Virtual Digital Tv Channels and Analog Tv Channels. Here are places to buy Tv antennas and etc. http://www.solidsignal.com , http://www.starkelectronic.com , http://www.3starinc.com , http://www.amazon.com . . Here are some online Tv Guides , http://television.aol.com , http://tvlistings.zap2it.com , http://www.titantv.com
