Old 20-Jun-2017, 7:58 PM   #51
Any thoughts on what might be going on here? Is this some form of destructive interference where some very low amplitude CH-25 signal passes through the VHF-pass filter and destructively interferes with the CH-25 coming through the UHF-pass section?
I think it is possible. You have a very weak CH-25 signal coming from BOTH antennas.
Is this an example of UVSJ's "not always doing what they're supposed to" ?
It's an example of trying to make a UVSJ do what it was never designed to do.
and why I've seen several people on this forum recommend using separate coax runs and an A/B switch for UHF and VHF instead of using a UVSJ combiner?
That can work well if the antennas are aimed at the transmitters.
If you want reliable reception of WNNE, the antenna must be aimed at WNNE.
