Another update. This is getting really interesting.
Swapped out the DAT MIX for the U4000 again. This time around I installed a rotor. By doing this I was able to find a spot at 100 degrees (by accident) that allows me to get both Ch. 2 and 7 and 22 from Dayton with the antenna at the same height. Then if I rotate it back to 15 degrees I am able to get Ch. 26 though it is quite weak. Due to the screwy nature of this location it is obvious I am getting 2, 7 and 22 off a reflection from a building. But the signals are reasonably strong enough to watch and I am not seeing any multi path break up at least during normal weather conditions.
In light of this I will probably try the DAT MIX on the rotor and will see if it too can pick up Ch. 2 and 7 and 22 at 100 degrees. If so, then I can continue to use it. Otherwise, I will probably buy a 8 bay which will give me just enough additional gain to reliably receive Ch. 26 here.
