Old 14-Jun-2017, 11:24 PM   #22
Originally Posted by olimazi View Post
Guys, I swapped out the balun with a new one and it did not help my reception, sigh.
I am wondering if the connection between the UHF and VHF elements on the antenna is the issue - see pic.
https://goo.gl/photos/vT6N7UQ7MoGwJFNMA
Yes, it could be the issue if either of the wires from the UHF section touch any metal parts of the antenna on their way to the CB-8269.
OK. So if I test with the clips and one part of the antenna is bad, then I guess I need a new antenna?
Maybe not, if you can fix it. Also, your antenna could be OK and the UHF signals might be bad.
Can you recommend a balun w/ clips like the one in the video?
I used to recommend the Channel Master 94444, but they redesigned it but kept the same model number.
http://forum.tvfool.com/showthread.php?t=16297
The WINEGARD TV-2900 gets good reviews.
Add two alligator clips that have screws.
