then I guess I need a new antenna?
That is probably unnecessary, just need to identify the actual fault so it can (usually) be fixed. It's probably not the antenna's main components, anyway.
Can you recommend a balun w/ clips like the one in the video?
You would have to make it from the component parts (balun, clips, soldering, etc), it's a one-off example.
