Old 14-Jun-2017, 12:46 PM   #20
olimazi
balun
OK. So if I test with the clips and one part of the antenna is bad, then I guess I need a new antenna?
Can you recommend a balun w/ clips like the one in the video?
Than you.
The video shows more than that. It also says to test each section of the antenna for proper reception using a conventional balun with clip leads connected to the UHF section and then the VHF section without using the CB-8269.
olimazi is offline   Reply With Quote
