Old 12-Jun-2017, 11:54 PM   #19
the video shows how to troubleshoot the balun to see if it is the cause of poor reception... but I have replaced the balun with a new one, that would eliminate the balun as the culprit.
The video shows more than that. It also says to test each section of the antenna for proper reception using a conventional balun with clip leads connected to the UHF section and then the VHF section without using the CB-8269.
