Old 12-Jun-2017, 6:48 PM   #17
olimazi
balun
thanks rabbit... the video shows how to troubleshoot the balun to see if it is the cause of poor reception... but I have replaced the balun with a new one, that would eliminate the balun as the culprit.
I did notice the uhf/vhf lines coming into the balun had some oxidation going on, if you will - from moisture? I will try to scrape that off/file it down to see if my reception improves.
The next step is to test each section of the antenna for reception as shown in the Winegard video.
olimazi is offline   Reply With Quote
