Thread: Help
Old 9-Jun-2017, 1:20 PM   #5
Jake V
Since your Baltimore stations are quite strong, I'd try the Antennas Direct C2MAX pointed to Washington, DC (flat side aimed towards DC / 250 degrees with a compass). I expect you would pick up all the Baltimore stations in green and a good number of the DC stations in yellow. [You might need to point and re-scan a few times.] The exception might be Channel 7 from DC (ABC), which is VHF-HI.
Try it with one television first, and try it in a few locations before mounting. You should be able to split to support 4 tuners, but you might need to amplifier.
You have nothing to loose, especially in you purchase the antenna from a retailer with a good return policy.
The Winegard 7694p is a very good antenna, but more directional.
