Old 8-Jun-2017, 1:06 AM   #4
JoeAZ
In the near future, WQED PBS Pittsburgh will move to Rf 2 from
Rf 13. That will require an antenna capable of receiving Rf 2-51,
eventually 2-36. The Channel Master 3016 is compact and durable
and reasonably powerful. http://www.homedepot.com/p/Channel-M...3016/203763042
I'd use RG6 cable and keep it under 50 feet. Be sure to ground the system.
I'd start aiming, due South and do scans. You should be able to get some
channels from both Pittsburgh and Johnstown/Altoona. By tweaking the
antenna more southwest you'll gain some Pittsburgh and lose some from
Johnstown/Altoona and vice versa. You could go with a much more
powerful antenna, Winegard HD8200U but that would destroy the budget.
https://www.amazon.com/Winegard-HD82.../dp/B001DFS4BI
