Old 3-Jun-2017, 9:17 PM   #7
I want to make sure I am not overdriving the tuner with my inline amp.
Since you didn't give us a tvfool report, I had to make an estimate of your location to give a better answer.
Your signals are quite weak and 2Edge (interference from terrain). You will need a high gain antenna for UHF and VHF-High aimed at 60 degrees magnetic.
You should use a preamp at the antenna. If you have more than one TV, try a passive splitter before adding a distribution amp.
WQPX is the weakest signal you will be able to receive, except when there is signal enhancement from Tropospheric Propagation
