Thread: Picture quality
Old 1-Jun-2017, 1:03 AM   #20
harold
I was just checking the translator in Quanah and it has two channel 7's. One is Lawton Ok. frequency 31, and the other is Amarillo TX. frequency 39. How does that work? I've noticed on the TiVo a channel from several towers will be in the list is that how that would be? Display channel with each, or choose a frequency? Both are ABC but have different sub channels.
Am I missing something but I've read that NM 0 or above should result in a suitable signal. Frequency 29, and 31 are the only two I'm interested in. According to tvfool the NM for 29 is -1.9 and 31 is -2.1.
My logic says with an antenna with +13 gain I should be able to get those with a +10 cushion! Or do I need to go higher and get the NM above zero? Thanks!
harold is offline   Reply With Quote
