Old 29-May-2017, 3:42 PM   #12
Does splitter go after the amplifier that plugs into wall?
Yes. Generally, it's a best practice to install the amp as close to the antenna as possible. Split the signal downstream from the amp.
Like why do u 5-1, 5-2
Channels may be identified by their displayed channel (virtual) number, real (RF) channel number, or by the station's call letters. Identifying by network affiliation is usually the least useful as they then require additional look-up in order to identify the underlying real channel which determines the antenna requirement.
