Thread: No Reception
Old 28-May-2017, 7:10 PM   #14
JoeAZ
The Mohu Leaf 50 comes with an amplifier. Are you using the amplifier?
I suggest you try the Mohu antenna outside (no amp) using the coax that goes to the RCA antenna, to see if the coax is OK.
I have been under the impression that if you try to use an amplified
antenna without powering the amplifier, it would not allow any signal
to pass through. Sort of like how a guitar amp operates. That is why
I suggested removing the outside antenna to test both the antenna
AND cable as well.
