Thread: No Reception
Old 28-May-2017, 3:48 PM   #11
Raising the height of the antenna 6 feet probably would not help, since I am getting no reception, right?
Right
No, don't remove the RCA ANT751; leave it where it is.
The TV and the Mohu seem to be OK because they give you reception, but the RCA outside doesn't work.
So, you have to make some substitutions to find out if the antenna, coax or antenna location are bad.
The Mohu Leaf 50 comes with an amplifier. Are you using the amplifier?
I suggest you try the Mohu antenna outside (no amp) using the coax that goes to the RCA antenna, to see if the coax is OK.
