Thread: No Reception
Old 28-May-2017, 2:53 PM   #9
JoeAZ
Originally Posted by fkgrable@aol.com View Post
What do you mean "remove the new antenna from the roof"? The antenna is actually on the side of the house at the level where the roof slopes down to the side of the house.
The TV is fine. I have already used DTV/TV input to scan for channels with an indoor antenna, receiving 40 channels, but not receiving the one hi-vhf channel I want.
Ooops, remove the antenna from the side of the house, connect to 50 ft
of NEW RG6, connect to your TV, point in an Easterly direction and
do a scan....
"I am using two pieces of cable using a connector to put them together. Maybe a single 50' piece would do the trick?" That is cause for concern... Either the connector or connections on your cables could be damaged or defective...... Hope this helps you.
