Thread: No Reception
Old 28-May-2017, 12:40 AM   #7
JoeAZ
Here is what I would do.
I would remove the new antenna from the roof.
Connect the RCA antenna to 50 feet of NEW RG6 cable
and see what you get. If it works, the other cable
is bad or the connectors/connections are bad. If it
doesn't work, replace the balun/transformer. It that
works you know what the problem was. If it still
doesn't work I'd try another television. Are you
set for OTA/antenna??? Are you on the correct input?
Regards,
Joe
