Thread: No Reception
Old 27-May-2017, 5:07 PM   #1
fkgrable@aol.com
No Reception
http://www.tvfool.com/?option=com_wr...e6a4be54e88e7c
I was checking reception with an indoor antenna, and received all the channels except for one hi-vhf channel I need. ( I got 40 channels) I decided to put up RCA ANT751 to receive this one channel as well.
The antenna was installed at a level where the roof edge meets the side of the house. (Should I go higher?)
I pointed the antenna's short elements toward the towers. (All channels I need are between 83 degrees and 95 degrees with a range in miles of between 20.2 miles and 33.4 miles in an easterly direction.) All elements were unfolded per instructions.
I attached the transformer to tetrapole studs, and attached transformer to coaxial cable. I ran the cable thru attic and down interior wall to tv, attaching the coaxial cable to dtv hook up on back of tv. (Approximately 40' of cable)
I ran three or four scans in antenna mode, and got 0 channels.
My tv does have a digital tuner.
Any help is appreciated.
fkgrable@aol.com is offline   Reply With Quote
